ok here we go im trying to pin this down ,let me know if this is normal or if this needs some tech help here please .i have a auto meter gauge it has the peak button and memory button on it fairly exp.$260.00 i thought i was getting the best .iv got the map hooked to my vac with my meth . heres problem number 1 ,iiv got a vortec s/c w/ a 3.33 pulley stock from factory not touched.when i go up the road i fluctuates w/ my peddle into the boost o -10 psi of boost .i not getting into the boost at all .is this normal i was going 80 up the hway tnight andit was reading 5 lbs of boost if i lightly pushed the peddle it would jump to 10 lbs of boost.#2 when i get into boost it shows like 14-15 lbs of boost whats up here ,i know im probably only really getting 5-7 lbs of boost from factory pulley .oh when it does show vac going down it only showing 10/12at idle psi or so .i only have a small cam i dont think its that at all .its just the gauge is all over i mean just pat the gas and its got 10 lbs of boost .id love too hear any sugg.thanks the wiring was pretty self axplanitory but maybe i screwed up .{no way2wires and a plug}
