Quote:
Depends, is your PCM locked? Can you flash tunes to it? I thought I read somewhere that he is sending you PCMs still. If he has to send you a PCM, chances are that you have a locked PCM at this time and you won't be able to make changes to it, only log driving cycles. If you want to start tuning it yourself you'll have to get an unlocked PCM. Allen has to send locked PCMs to protect himself from accusations of bad tunes when amatuers make changes to his tune and burn their engines up. If you don't know what you're doing it is easy to burn one up. You can also toast your transmission if you make some bad settings.
as far as i know he sent me a unlocked pcm ,thats what he said when he sent the hp and new tune
