Quote:
Ok so I found the problem with the PRNDL and indicator lights. Apparently when I was installing the DBW pedal assembly, the ignition wire came out of the interior fuse block. So now that is fixed.
The truck will still not start but it will crank. Have fuel. Have spark. I'm wondering if the VATS is messing with it and cutting the injectors.
How much do you charge to just take out the VATS and fix the VIN in the PCM? I want to get a complete tune from you but I want to at least get the truck started and know that it runs ok.
If the pcm has not been programmed, then there is vats in the pcm, and it needs to be turned off, that will keep the engine from starting. the engine turns over, the pump primes, so you probably have everything correct.
