Quote:
You can run 2.02 int. with 1.57 exhaust but it will require some machine work to the valve seats. With this done you will need some port work done to match the new oversized valves. Being that you are FI milling the heads much is not such a good idea because it will decrease the amount of boost you can run with the same octane rating you were running before. As far as port work most of your gains will come from working in the bowl area and the short side radius of the ports especially the exhaust. mario
who makes the valves? and i wont need to mill the heads for valves correct? the compression is too high as it is
