Ok I just got my harness today and my Fans have been sitting here for about a month...
How do and where do you mount the fans? I know right behind the radiator but Is there a special clamp to buy? or screws?
<div class='quotetop'>QUOTE(Aggie @ May 25 2007, 07:27 PM) [snapback]94701[/snapback]</div>Nope & nope. These fans were never designed to go on your truck. So guess what...you have to make them work! Although my truck is a bit older than yours, the bottom of my F-body fan shroud slipped right into the lower area of the core support, nice & snug, right behind the radiator. Mine was the 28" 4.3 Vortec V-6 radiator too, so they are probably simular. Then I simply fabricated two small aluminum L-brackets & thru-bolted them with small 10-32 machine screws, locknuts & washers, at the top, through the core support/shroud. Real easy actually. Hope this helps.Quote:
Aggie, need a PM from you, don't forget!!!!!
