okay let me start the list over cause i had people back out on what they wanted
242/242 .595/.595 112LSA cam....$300
5.3L short block...crank rods, pistons, great motor just spun a rod bearing, the crank bolt broke in the end of the crank and Blaines said they would charge $50 to get it out add the $63.50 for the rod bearings and you have a really good strong motor block is already taken apart so you can check it yourself....$50...sold TwoBit
5.3L cometic head gaskets .0040 quench used once......$50
30lb injectors from a 8.1L........$100
Mildly ported and polished 317 heads with 5 angle valve job and comp 918 springs 300 miles on these.......$500...Sold
Comp 7.4 hardened pushrods......$75...sold
Built 4l60e transmission with warranty built by Lonestar Transmissions.......$1,000
SS front bumper with grills painted black.....$250
Roll pan black also.....$75...pending
i am a little open on these things so make an offer
