Here around june-ish I am going to be doing the 4.3 to 5.3 swap and on this thread http://forum.ls1truck.com/index.php?showtopic=9571, it is said that you need these fuel lines:
Fuel Lines: The stock fuel lines will not work with the new motor, you will need
2 EAR-165056ERL -6 - 5/16 AN to tubing connectors Male end
2 EAR-165006ERL -6 - 3/8 AN to tubing connectors Male end
2 RUS-658490 1 ft sections of pre assembled 5/16 Steel braided hose with female ends
I ended up with what Im pretty sure is a brand new complete fuel line system from a 2001 ext cab 5.3 Z71. Here are some pictures of the complete setup with the paper that has some numbers on it. My question is, are those part numbers listed above, can I use any of whats in the pictures below for the 5.3 thats going into my trucK? I hope I would be able to use some of these parts. Let me know if I can use any of these:
http://i39.photobucket.com/albums/e1...k/float024.jpg
http://i39.photobucket.com/albums/e1...k/float022.jpg
http://i39.photobucket.com/albums/e1...k/float003.jpg
http://i39.photobucket.com/albums/e1...k/float002.jpg
http://i39.photobucket.com/albums/e1...k/float001.jpg
Thanks,
david
just cut the ends off your v6 lines and use fuel hose and clamp them
Which specific lines need to be replaced on the V6 anyway? I wanna crawl under the truck, or I mean jack it up really high so I can crawl under it, and then look to see which ones and where I am going to cut.
