I've been reading the pinned post about obs to ls1 and you say to use a corvette fuel filter. I know you said in the post that one was used most often, but why not a stock camaro filter or one from one of the trucks? Thanks.
It has a built in fuel pressure regulator. With a standard filter you will have to add a fuel pressure regulator to keep from pushing too much pressure to the fuel rail. This is assuming you are running a fuel rail with only an inlet and no return.
