alright got the 4l60e all built up, stall converter, tune ,exhaust, what would be the next best upgrade to make a deference in my truck for resonable price? (cam, heads, ls6 intake) lets hear the ideas.
<div class='quotetop'>QUOTE(blacksierra03 @ May 5 2007, 04:39 PM) [snapback]92458[/snapback]</div>NEED A STRONG REAR AND A GEAR 3.73-4.56? GET THE REAR BULLIT PROOF AND THEM GO TO THE MOTOR. HEADS, CAM, PORTED TB, ETC...Quote:
JAMEST
List your current mods if you have any other than tranny. If tranny is it then you need a rearend because it will NOT last long. Trust be I know. I lost rear end, carrier, gears, drive shaft, yoke and even the new solid u joints.
http://img1.putfile.com/thumb/2/4518530611.jpg
http://img1.putfile.com/thumb/2/4518531157.jpg
Next get a really good tranny cooler to make that new tranny live longer.
Part numbers can be found here below. They were provided by Allen Nelson of Nelson Performance.
http://forum.ls1truck.com/index.php?showto...&hl=jj'
Pictures of this unit installed can be found on Nelsonperformance.com I have not uploaded mine to put file yet.
http://nelsonperformance.com/YellowTruck2.htm
Next get a performance tune. If you are one of the lucky folks from texas make an apointment with Dr. Nelson and let him tune your truck. When he does The sky will open and Angels from Heaven will appear and you will hear them sing. The pope is also likely to bless your truck.
After that stop by TRT and order a 408 which can be seen below.
http://forum.ls1truck.com/index.php?showtopic=11183
Then :nx:
and or Turbo :burnout:
don't worry about paint and stuff you will too fast for the paint to stay on your truck.
Oh yeah the link below is great also.
http://www.gmhightechperformance.com/tech/...modified_truck/
<div class='quotetop'>QUOTE(blacksierra03 @ May 5 2007, 05:39 PM) [snapback]92458[/snapback]</div>OOOps forgot you had the tune sorry I am a dumba$$ sometimes.Quote:
<div class='quotetop'>QUOTE(zeake @ May 5 2007, 06:37 PM) [snapback]92462[/snapback]</div>so what is the best rear end setup for the good old gov bomb factory 10 bolt? Detroit locker , Eaton, ?Quote:
Then :nx:
I like the Auburn myself.
<div class='quotetop'>QUOTE(RedHeartbeat @ May 6 2007, 10:51 AM) [snapback]92487[/snapback]</div>I second that Auburn PRO posi.Quote:
