hi guys i want to lower the back of my pickup,and as you are aware,nobody makes a kit over here in aussieland,does someone have the measurements of the c clips,that i can make,and also do i need to change,all the hangers and brackets,i have looked at the DJM kits but they donot have dimensions,
any help would be gratefully appreciated, thanks glenn
i should say flip kit not( hit)
Belltech makes the nicest flip kit on the market. I'm sure any major dealer will ship them to you. Check out www.jegs.com or www.summitracing.com.
thanks red i have just ordered,a flip kit from summit
usd 225.00 plus shipping.(orsome)
as i said before this site rocks
since you are droping the rear, what about the front?
i have 2in bell tech on the front at the moment
what do you suggest to get it down another 2 in?
Cut one round out of the coils.
ultrabluea9x, I have a 4/5 drop on my truck using BellTech 2" drop spindles and 2" lowering springs in the front with shackles, hangers and the overload pulled to achieve the 5" drop. If you want to go lower than 5" you'll have to go with the flip kit. By flipping the rear you also be able to use a universal traction bar set if you need them. I had to order a set of Caltracs for mine. The only problem with the drop spindles is the diameter and width of the front wheel. If you decide to go with a 9" or wider front rim it will hit the upper and lower control arms. An 18" or larger wheel is ideal for drop spindles without having to mod anything. JFYI.
