What would be a good Cam for a fairly stock truck with LT's intake and exhaust and tune coming?
Id go with a tr220 just get you a 2800 stall and thhat thing will run strong
I'm not goin to run some out of the box cam. I have a friend that can get me any custom grind for cheap. Whats the use of running a "usual" cam??
<div class='quotetop'>QUOTE(Looney102 @ Apr 23 2007, 10:36 PM) [snapback]91153[/snapback]</div>Well for one its a proven cam that does great in the 5.3... The best IMO, If you have a hook up for a cheap custom grind, I woud do a high lift 220/220Quote:
<div class='quotetop'>QUOTE(Motocycleguy @ Apr 24 2007, 12:33 AM) [snapback]91158[/snapback]</div>Yup---that is what mine is..custom grind Comp 220/220 .581/.581 114 LSA +3 degrees of advanced timing. Going to run a 2600 stall..should work well...Quote:
Ill cut you any cam you want (380) and install it for free!!!
TRT :thumb: :thumb: :rock: I like the 228 cams on a 114LSA myself. BUT, you do need at least a 2800 stall.
<div class='quotetop'>QUOTE(BEATERTRUCK @ Apr 24 2007, 11:59 AM) [snapback]91248[/snapback]</div>Damn that a great deal dude! What brand cam do you use and how much for just the cam and no install?Quote:
<div class='quotetop'>QUOTE(Motocycleguy @ Apr 24 2007, 10:27 PM) [snapback]91311[/snapback]</div>Took the words right outta my mouth...Quote:
<div class='quotetop'>QUOTE(Looney102 @ Apr 23 2007, 04:43 PM) [snapback]91080[/snapback]</div>Quote:
I'm not saying it just because I'm selling one, but a lot of guys like the 216/220 since the power band starts basically from idle and climbs on up.
As far as why you would want an "out of the box" cam - the reason is that they (Comp, Thunder Racing, Lingenfelter, Lunati...) put a ridiculous amount of research and development into the cams to determine what will work best with a given vehicle. That's why you'll find guys that swear by a certain cam. Some swear by the 216/220, others by the 220/220 or 224/224.
A lot of those guys have been through a number of cams and like a certain one for their own reasons - where th powerband is, where the torque is, how it idles, how it lopes, gas mileage, tease of tuning, etc.
Go with something smaller than a 220/220 in a truck.
<div class='quotetop'>QUOTE(BEATERTRUCK @ Apr 24 2007, 12:59 PM) [snapback]91248[/snapback]</div>Quote:
TRT :thumb: :thumb: :rock: I like the 228 cams on a 114LSA myself. BUT, you do need at least a 2800 stall. [/b]
hell ya!!!! already thinking about pulling mine and trying another size...
