Quote:
Hello all who have aftermarket cams,
Does anyone tow with their cams and how do they act, are they still ok or does it even make a difference?
How much does the trailer (trailer + Camaro on it) weigh? Around 5.5k lbs? You should look into a cam with a lower lift. A .588 is a little high if you are doing some towing. There are cams called "RV cams" that have extremely low duration numbers so that the motor makes most of it's power in the low RPMS. RV's, 4WD's, Rock crawlers, etc all like to use those cams. If you find a good mid-range custom grind cam, you can have a few degrees of advanced timing (+3 or +4) put on it so that the power comes in a little sooner. Check out
