Quote:
always after a hard interstate pull or any extended period of high RPM's. It will quit after awhile. And its always in the same spot. Same place i killed the factory lifters D/S rearmost lifter (forgot which cylinder)
SOUNDS LIKE A STICKY VALVE. RUN A BOTTLE OF LUCAS GAS TREATMENT THRU IT. IF IT STOPS, ITS A STICKY VALVE. PROBABLY HAS A LITTLE BUILD UP ON IT. MINE HAS DONE THAT BEFORE. I RAN A CAN OF B12 INJECTOR CLEANER THRU IT AND IT STOPPED. NOW I USE LUCAS TREATMENT 2 TIMES B/W OIL CHANGES.
