just put new pads and calipers on the truck today the passenger side was not reliving pressure and the truck would damn near not move. i thought naturally with it sittin for a few years they were seized, so i pulled the calipers apart and they were quite nasy on the inside of the piston bore so i replaced them went around the block and the pas. side still wont relive pressure. its draggin real bad, i made sure i lubed up all the contact points and sliders real good. could it be the master cylinder thats causing this, its pretty bad at 35 if you let go of the wheel u will go ditch cleaning. any help would be great!
