is it good idea to block off the egr valve setup or will the truck not run correctly, if it does give a performance boost is there a kit or is it strictly home made deal. oh and the spark sensor mounted next to the tbi has a vacum connection on the rear side that is not hooked up to anything just wondering what hooks up to it, if facing the truck it would be the rear bottom vacum fitting. should i just cap it off?
- You may not post replies
- You may not edit your posts
