Results 1 to 10 of 19
Thread: Got an oil change
    May 2006
    Waco TX
    Finally got sythetic in. I can't tell a huge diference, it seems to run a little quieter. The mechanic suggested Mobil 1 sythetics. So thats what I got. Just letting yall know!
    You may not be able to tell. But your engine definately will. Mobil 1, Royal Purple, and Amsoil are the top three, i feel that are the best synthetics to run in an engine.
    DBYRD Guest
    yeah, ive heard GREAT things about all of them, AMSOIL is the route im gonna go, although i dont think mobil is a bad choice either. royal purple doesnt last as long from what ive heard, not that id go to the limit, but makes me think maybe it isnt quite as good.
    Jun 2004
    george west texas
    they are damn good oils...i have used each one of em and are all the same....
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
    Jul 2005
    Loganville, GA
    Royal Purple is what im running, ive heard it was the best plus i can get it for $3/quart, but like they said mobil, ams are good too
    Jan 2006
    I run mobil 1 in my truck. I just switched to AMSOIL in my harley and I can tell a big difference. It runs quiter and cooler. I think I may switch to it in my truck soon.
    Jamest
    12 Sec. Club! SOLD
    SOLD***
    Jul 2006
    College Station, TX
    I run mobil 1 synth. 5w-30. How much does amsoil cost?
    2004 EXC Silverado 6.2L
    Mods:
    Jul 2005
    Loganville, GA
    Somewhere around $6 quart
    Oct 2005
    Houston, Tx
    its funny. i was thinking about this same thing yesterday. my truck is approaching the 36,00 mile mark soon. after that i plan on syn oils too.
    Apr 2005
    belton, tx
    I was told the syns are a bit "thinner than the reg oils. Therefore, shoudn't it be not as quiet? I would think a thicker oil would reduce the valvetrain noise. Gues it all depends on the w rating .
    2013 2wd Z71 6.2 crew cab
