Results 1 to 10 of 10
Thread: pulleys
    i have been looking at buying the pulleys from allen once they come back in stock. i had a few questions though before i buy them.
    - what size would i see the most benefit from?
    - where exactly would i see the benefit at getting new pulleys? top end or bottom end?
    - would it be a good investment to buy the pulleys now so that i would be able to use them on the motor swap i plan on doing in the future?
    - would the engine run hotter say for instance in traffic with a different size pulley on there?
    any input would help.
    thanks,
    david
    Jan 2006
    <div class='quotetop'>QUOTE(duckysbht &#064; Sep 13 2006, 12&#58;17 AM) [snapback]64931[/snapback]</div>
    thanks,
    david
    DUCKY,
    MAN PUT A TURBO ON THAT BEAST AND BE DONE WITH IT&#33; AM I GOING TO HAVE TO SAVE UP AND BUY YOU A TURBO? IT MAY TAKE A WHILE.
    JAMEST
    12 Sec. Club! SOLD
    SOLD***
    Mar 2006
    Mesquite
    thanks,
    david
    I believe (someone correct me if I&#39;m wrong) his pulleys are for Radix...they&#39;re not underdrive pulleys if that&#39;s what you&#39;re thinking.
    Mar 2006
    Dawson Springs KY
    <div class='quotetop'>QUOTE(DamnYankee &#064; Sep 13 2006, 02&#58;42 PM) [snapback]64986[/snapback]</div>
    I&#39;m thinking that your thinking is the correct line of thinking.
    2011 Silverado LT 5.3 bone stock (for now)
    (gone but not forgotten)02 Avalanche Z-71 Vortech supercharged 3.12 pulley 10psi, SMC meth injection, 33 12.50-17 procomp AT, 17x9 procomp wheels, AVIC-N2 NAV, 4.56 gears, Detroit TrueTrac, 2500 stall converter, transgo HD2 shift kit, Vette servos, 80mm BBK throttle body, Edelbrock shortie headers Cold Fusion wet shot (60hp), and too many more mods to list. 8.86/18th 472rwhp/499rwtq
    <div class='quotetop'>QUOTE(KY_BOB &#064; Sep 13 2006, 03&#58;06 PM) [snapback]64988[/snapback]</div>
    i knew i was reading it wrong. i saw somewhere on there that it mentioned "radix" but being myself, i blew off the notion that it was for FI applications. oh well thanks for clarifying that up for me guys&#33;
    but i guess my questions still apply. is it a good investment to buy a set of pulleys know because i will be able to use them on a future motor swap? etc.
    Mar 2006
    Mesquite
    <div class='quotetop'>QUOTE(duckysbht &#064; Sep 13 2006, 04&#58;53 PM) [snapback]64993[/snapback]</div>
    They will help, but I think your money would be better spent elsewhere, even if it meant saving a little more. Gotta get a cam and torque converter in that thing.
    DBYRD Guest
    id like to see if allen would make everyone some pulleys on here like billets all the way around crank pulley, ac comp pulley ETC. i think itd make the engine look so clean, but i can imagine the cost. ud need efans to be able to see most of them, but i plan on efans anyway.
    Apr 2005
    Save your money Ducky. Put it towards something useful, like a turbo.
    Gone, but not forgotten!
    <div class='quotetop'>QUOTE(SCIV &#064; Sep 13 2006, 06&#58;12 PM) [snapback]65013[/snapback]</div>
    You and James both. I want a beastly v8 sitting in front of me, with eventually a turbo. not a whiny v6 that would barely crank out 300 hp with cam/stall/turbo/tune.
    DBYRD Guest
    a turbo on that v6 aint worth it, go v8 then go turbo on it down the road, stick to ur plans ducky, i dont think ull be dissapointed&#33;
