Thread: AGGhh Braided oil line
    Apr 2006
    Bellevue, Nebraska
    Has anyone in here(stupid question) ever worked with braided oil line. I got the line and fittings from Summit and it was a pain in the ass to put them on so I ended up having to peel back the first layer of steel braid to get the fittings on. Is this normal or are they always a bitch??? I'm almost done just have to find time to run the return oil line.
    Jan 2006
    I haven't worked with it much but from what I remember you are supposed to wrap tape around the end of it before you put the ends on. Does that sound right?
    [1/8 mile E.T. - 8.23 @ 82.86 mph w/1.82 60'] '98swb,4/6drop,20"RozziDeeps on 275/40ToyoProxes '98LS1/4L60E,TRCheaTR cam,Ported TB,Billet MAF ends,MSD8.5 superconductor wires,S&P midlengths,!EGR,!cats,2 1/2" true duals w/X-pipe,Dynomax Ultraflows,TCI 3000,billet servo,TCI deep aluminum pan,3.73's w/Auburn posi; Eclipse CD, Rockford 6 1/2's, Memphis 12's, Punch 200 ix, Punch 500x
    Nov 2005
    ohio
    i skipped that headache and had a SS oil return line made at a hydraulic hose shop with swivel ends.
    Apr 2006
    Bellevue, Nebraska
    <div class='quotetop'>QUOTE(Tim Z &#064; May 18 2006, 06&#58;16 PM) [snapback]53508[/snapback]</div>
    Currently in North Dakota. No good shops that I know of around here. the connections seem to be holding strong, but I haven&#39;t put any pressure though them yet. Hopefully tonight.
