Results 1 to 2 of 2
Thread: 2003 1500 solid front axle conversion with 1ton axle
    Aug 2011
    New Port Beach, CA.
    Hi I am doing a solid front axle conversion on my 2003 1500 chevy silverado. I have already done the the 4l80e swap. At the time I was doing the 4l60e to for 4l80e swap was when I decided that it was time to get reed of the problematic ifs that has hinder the off road capability of the truck. I had long travel but it was not good enough. So I decided 4x4 why not. The main problem I came across was a conversion kit. No one made one.
    My research should plenty of 2500 kits and conversion, but if you want one for a 1500 your stuck with leaf sprung front ends and the weak Dana 40 if you can find a 6 lug. That is how I can up with my own design.
    First i started with an axle that would fit under a 2500 and align with the factory transfer case of a 1ton. sense I had already installed a 1ton manual t case from a 1999 suburban that had the 454 engine, when i was doing the 4l80e swap. The axle i chose was out of a 2003 dodge 2500 4x4 with 4-10 gears.
    Another reason for that choose was that the wheel speed sensors are the same as the chevy.
    Next was leaf sprung, four link or three link? I really want this truck to have go off road ability, but I still want the stability of a street driven vehicle. So I went with the four link set up. Not the leaf or three link. The leaf just would not do what I wanted to do and the three link would be way to loss on the street.
    I have had the long travel on my truck for a long time and i used to the soft roll to the long arms. But none of the kits I have seen for the 2500 have a long travel option.
    Well I thought why not take a version of long arms that I had on my jeep xj and cross it with the durability of the shorter 4 link kits. I drew up some brackets and designed the kit with less then a 1/4 of inch axle roll through the 14-in of usable travel.
    The arms that I will be using are two 5-feet plus inch with a centered frame mount designed to also tie in the rear axles track bar.
    I will be putting some pictures on my album.
    6.0 MAX Blown
    Mar 2011
    Gibbstown, NJ
    This thread needs to be moved into the. "My Garage" sexction. And def. needs some pics posted
