Results 1 to 10 of 19
Thread: Cam opinions..
    Cam opinions..
    wanted some opinions from you guys. ill be getting a custom grind cam for my 06 lq4.
    cam specs are as follows: 227/227 .640/.640 112+4 LSA i know lift is high. thus why i
    ask you guys what you think about this going into a mostly stock 6.0? untouched 317s. mainly a bolt on truck. thanks for your input, greatly appreciate it.
    Arizona/Utah
    Need complete details of the entire build in order to give you a good educated answer. Those specs are a little odd to start with however. Stall speed vehicle weight gears tire height goals etc.
    dont really have goals as far as track times. just wanted to know if this cam would be a fun streetable cam. its an 06 lq4 & 4l80e combo. stock torque converter. 4.10 gears.
    Jan 2012
    DFW, TEXAS
    streetable? stock convertor? come on you know the answer to that
    is it on a dune buggy? what kinda of truck?
    Mar 2012
    west bend, wisconsin
    id probably use at least 3k stall for a cam with numbers like that
    1999 chevy silverado Z-71- 5.3, CAI intake, catback, nelson tuned, lpp lt's, vette servo, e-fans.
    lol sorry guys. it's a RCSB, not a dune buggy haha
    and yeah a 3200 stall is on my plans. would like to use this cam with the stock one though for a bit until I gather coins for a 3200.
    Jan 2012
    DFW, TEXAS
    do it.
    Feb 2013
    San antonio,tx
    Should be fine without the stall just save up n get a good one....
    4.8 FBO-PULLEY 228/228 CAM 4.10 GEARS TUNED BY NELSON...JUST CRUSUIN SAN ANTONIO!
    what do you guys think about the lift and stock 317s? i know the 317s will restrict the cam of some power but it should still work well ?
