since im still in the hospital with nothin to do ideas run wild in my head. what would u guys think about either a th350 or 400 with gear vendors and a paddle shifter? was doin some research they make paddle shifers that will work the tranny and the gear vendors where u can split every gear. i was thinkin full manual valve body and paddles. the only down side is u would have to be shifting all the time with the manual valve body like a standard. u can program the shifter to where it has 6 gears for up and down shifts. the gear vendors is suppose to be able to up shift and down shift at wot. the reason i was thinkin about this i cause of the 6 speed autos and how cool it would be to have 6 gears in the older trucks like my 03 where u couldnt make the new trannys work. i wont ever have the money to do it just an idea im puttin out there to get some feed back for.
