Thread: Oil pick up o ring?
    Oil pick up o ring?
    Just wondering how many of you have replaced the o ring in the oilpump pick up tube? And did it cure the lifter tick? Recently purchased truck has 175000km on it and has a small tick. Its there sometimes and gone others? Ive read and heard that the o ring could be split causing the lifters not to fully pressureize? Will changing the O ring fix this and how does it affect longevity etc? Thanks for any help!!!
    Dec 2008
    South Carolina
    when the 0-ring went bad on mine i lost ALL oil pressure...but just about every truck i'v ever seen has that tickin noise, it usually goes away once the engine warms up. i'd just drive it and not worry bout it bro...mines been doin it ever since it was new and still did it when i put a new o-ring in the pick up tube. its annoying but wont hurt anything
    2008 GMC Sierra SLE....370ci LY6 with some goodies SOLD
    Jan 2010
    Emmett, ID
    Quote Originally Posted by chvy=power View Post
    Did the motor have to come out to do the o ring? My 6.0 is having oil pressure issues. When cold it takes awhile to build pressure. Just wondering how much of a job im in for?
    1999 Silverado 2500LD EC, SB, 4x4, LT, 6.0 V-8 (LQ4), 4L85E, 4.10 gears & a G80. 4" homemade intake, 3" magnaflow 2 into 1, diablosport predator tuner.
    Feb 2010
    Odessa, texas
    Quote Originally Posted by BRONCMAN View Post
    no u dont have to take the motor out...just drop the pan..im not sure if your truck has the cross member under the oil pan..if so just take it out and drop the pan
    1983 Ford Ranger- 2.3 to 205k mile 6.0 swap
    Ok thanks! I just hate un necassary engine noise! Especially when I know what it is etc. Thanks for letting me know it doesnt cause any problems though!
    Jan 2010
    Emmett, ID
    Right on. Thanks. Didnt know if the motor had to be lifted or not.
