Results 1 to 8 of 8
Thread: The 60 is dying!
    Dacula, GA
    The 60 is dying!
    Ok so I'm somewhat new here and I've got a question about my tranny. The truck has 148,xxx miles on it and the tranny is starting to go. I had planned on swapping out the old 4L60 for a 4L80 with future plans of dropping a 408 in and shooting for sub-12's. Not sure of power adders yet...I'd like to keep it N/A, but you never know. My question is would it be better to go ahead and do the 80 swap or just rebuild the 60? Maybe a 65? Any help and advice is greatly appreciated.
    '02 GMC Sierra 4.8L
    CAI, Granatelli MAF, 90mm TB, 1.8 roller rockers, JET tune, true dual Flowmaster race mufflers.
    yes do 80e
    Jan 2010
    Cedar Park
    depends on your funds, read up on what is required to do the 80e swap.. 80e is much stronger
    Nov 2009
    chicago, il
    Who cares what it costs, it'll save him money in the long run.
    Depends are you 2wd or 4wd. My 80 swap cost me about $2100ish but I'm awd so there's an estimate for you but my vote is 80 otherwise it's like hitting yourself in the head with a hammer
    [Today 11:15 AM] MidnightRider: justin= generalvehicles.com moderator
    Dacula, GA
    yeah its a 2wd and the swap is within my budget. theres no major modifications required with the swap is there?
    '02 GMC Sierra 4.8L
    cross member just add a plate with some gussets to it for the mount youll need a vss plug and enough wire to wire to run it from the pcm to the tranny, and shortening the driveshaft
    Dec 2009
