Results 1 to 10 of 14
Thread: 4.8 5.3 bore questions
    I have a 4.8 and can get a 5.3 if I want to spend the money. Question is: Arent the block on the 4.8 and 5.3 the exact same? the 4.8 just wasnt bored out as much? why couldnt I bore out the 4.8 to the 5.8 bore or even more? then I would have a larger bore and a quick spinning assembly.
    Augusta, Ks
    Same block different stroke and the 4.8 has flat top pistons.
    2004 Buell XB12s
    5.3/6.0 crank in a 4.8=high compression 5.3
    Aug 2009
    Devine, Texas
    arent the 4.8 pistons dished and the 5.3s are flat tops?
    Edit: Never mind your rite. lol
    LS6, 222/224, Yank ss3600, 4.10s, Thorleys, HP tuned
    Cromwell, CT
    it would be a 335
    you could do it but i don't think there is an off the shelf piston that would give you enough compression
    01 ecsb 5.3 4x4 z71
    Avalanche 17s and a pant load of miles
    61 Corvette
    350, 4 speed, 4.56's
    32 Ford 4 door sedan
    keeping it "stockish"
    Augusta, Ks
    I think hes gonna buy my LS6 flat tops and do an iron LS1
    2004 Buell XB12s
    Wichita KS
    or buy my 5.3 and use his flat tops!
    2006 Trailblazer SS RWD
    Augusta, Ks
    Quote Originally Posted by MYSHTBX View Post
    True story.
    2004 Buell XB12s
    Wichita KS
    so many options!!!!
    5.3 and a 228r cam and have 400 bucks in it!
    Augusta, Ks
    Someones a good salesman.
    2004 Buell XB12s
