Thread: old school tranny issues need help pics...
    Exclamation old school tranny issues need help pics...
    My tranny went kaboom today...1984 350 tranny... My drive shaft had a huge dent in it and it was givivng me some pretty bad vibrations around 55-60+ miles per hour. I replaced the shaft with one that was 1/2 inches longer. tranny has been slipping a little for about a week any how...So I pulled the tranny and the rear shaft wobbles pretty good around the tail shaft but I dont know how much is too much...then I saw deep ridges inside the torque converter and the input shaft..... I have reverse but no forward. What is wrong here just a torque converter of the whole tranny?????thanks for any help.
    inside of torque converter
    http://i114.photobucket.com/albums/n...o/IMG00079.jpg
    shaft going into tranny...
    Well, there will be some end play in the output shaft...but how much? We don't know.
    When you replaced the DS for one 1/2" longer, did you make sure it didn't shove up into the output shaft too much? Not totally sure, but does a TH350 have a 1310 slip yoke?
    If you have no forward gears, then I would suspect your input sprag is shot. Since its an 84, I would go ahead and do a full rebuild.
    I found a 400 for 200 bux so imma swap it out tomorrow but Im thinking if I can find a 700r4 before then I will go with that for the overdrive
