Results 1 to 5 of 5
Thread: 2.00'' valves in 706 heads?
    Tyler, TX
    hey guys, i have a brand new set of valves out of ls2 heads, and i was wondering if i could easily get the 706/5.3l heads upgraded to 2.00'' valves
    i know i'll have to do some work in the chambers, but i don't really care to forego the expense of a whole new set of heads.
    www.tjc.edu
    Pittsburgh, PA
    they used to install the 2.0 valves into the 5.3 heads but TSP found out that installing the larger valve actually hurts the flow of the head since the runner was never designed for that size intake valve
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Tyler, TX
    well that sucks, but i guess some porting wouldn't hurt it
    www.tjc.edu
    With the proper machining work--I am sure you can have this successfully accomplished.
    Doesn't TSP install 2.02" intake valves on their Stage 2.5 setup? With their researched machining/flow work, they get some damn good flow from 862/706 castings...
    Pittsburgh, PA
    if you search in the GEN III section of tech for this type of post you will see two of the guys from TSP speak on this subject
    412 Motorsports
