Results 1 to 10 of 11
Thread: L33 5.3 and boost?
    S.A. Texas
    L33 5.3 and boost?
    Some things have come up and I need to get the truck running. I found a L33 5.3 with 20k on it for 650. I am wondering if this will handle 8-10 of boost will no issue for a while. So my built motor is on hold for a while just needing some info in the L33 with boost. Thanks
    Crossett,Ar
    I think it would work out well, Should have 243 heads on it I believe.... Should flow nice
    Slimsilverado Guest
    If im right compression on that engine is higher that will have some effect on your boost..
    My LM7 does just great with boost. If your worried, do ARP rod bolts all around, springs/rods. I'm running 12lbs on just springs/pushrods.
    Wasilla, AK
    Quite a few others have L33 with 10-12 psi and it works well. I wouldn't hesitate, it sounds like a great price.
    Aug 2004
    Magnolia, TX
    S.A. Texas
    Thanks guys Good read jason
    That is a good read. Nice find
    Slimsilverado Guest
    the L33 just has higher Compression Ducky thats all i was worried about
    Good price Mark. Guess you knew that. They have the same piston construction though so I guess you have found the boost creep problem.
