Ever since I install the LS1 cam, my oil pressure has been higher than normal. Runs about 45-50idle and under WOT will go past 80. It has a new cluster and sender so I know it's not that. Since it happen the same day of the install. Could my pressure relief valve gitting stuck or could there be something going on with the cam bearings. oh and at high rpm with oil past 80 engine shurges. What ya'll think? Motor about to come apart?
