Results 1 to 7 of 7
Thread: pushrod length ?
    Feb 2008
    Kanada
    pushrod length ?
    What length of pushrod is required when using LS6 (243) head,they are from a 2007 Corvette.I will be using them on a LS1 engine, with a cam change (LUNATI ). Will they be shorter than the stock pushrod? (7.400") because of the longer valve stems? Has anybody experienced this before, iam just wondering what to expect? Thanks
    Jan 2007
    Burleson,TX
    you should be able to use stock length rods 7.4 just be sure to used hardened ones
    06 silverado CC Volant CAI/ Corsa Sport exhaust
    dynatech supermaxx headers/cats
    LPE GT2-3 cam/ Comp 918's/ Rods
    Eaton LSD 3.73's
    IAT Shocks
    DANNY TRANNY w/2800 TCS billet verter
    275HP and 293TQ Pre Cam
    314HP and 303TQ post cam
    Hi James
    Assuming that the heads haven't been milled and the head gasket thickness won't change, it boils down to the base circle diameter of the Lunati cam lobes. That diameter is primarily determined by the lift of the lobes. Higher lifts require smaller diameters so the cam fits through the cam journals. If you can ferret that info from Lunati, we can give you a more accurate response than 'it should be OK.' Which cam are you going to use?
    Feb 2008
    Kanada
    I want to use Lunati's 60510, both intake and exhaust lobes are 0.513 lift . Dual pattern duration split of 212/218 degrees measured @0.050,and lobe seperation angle of 113 degrees. I will not be milling the heads,and will use GM head gaskets.
    That Lunati cam probably has a base circle diameter similar to the 2001 LS6 cam (19.3 mm), which is 0.4 mm less than a stock LS1 cam. The 0.6 mm longer valves in your heads will compensate for 0.35 mm less base circle diameter. You should be good to go. However, I would still send Lunati an email to confirm this.
    Feb 2008
    Kanada
    Talking
    Thanks Madd Maxx
