Results 1 to 10 of 13
Thread: Broke another tranny
Threaded View
    Jun 2007
    Well, I guess Its time to really do a 80e.It was nice and cool tonight ,so i went out for a good burst,took off from a red light,spiked 14-15# OF BOOST last time I looked up and bang,SOB.
    So what i need to know is ,what vehicle would be the best to get a 4wd 80e out of,do hd,s have em ?my 2wd hd does.
    Then what else am i gonna need to do?Im pretty sure ill need a gear for the transfer case [or is theyre a bolt in transfer that bolts on the 80],and a harness from allen,and does anyone have a diagram of theyre 4wd crossmember they fabbed up for the 80 to fit?shoot does the d/s have to be shortened also?Foggy maybe you can chime in ,I thought you did this.
    What upgrades do I need to do on the 80 ?shift kit?or is a stock 80 strong enough?
    Im so done with these 60-65 built azz trannies<i used billet eveything,5 pinion planets,etc Im done.
    I do have an spare truck or two for now so I can just take my time and do it right.God this does suck tho.I was just having fun.lol
