Results 1 to 10 of 29
Thread: crap,anyone strip the cam retainer bolts?
    i stripped two bolts that hold the retainer for the cam.
    Augusta, Ks
    Idk on those perticular bolts, but at the salvage yard if that happend we heat the bolt up a little bit and hammer in the nextd size. May not work for you but it does us.
    2004 Buell XB12s
    Sep 2006
    THE 405
    We had to use a slap driver on mine. I hate thos things. I'm puttin an older style plate on mine when I goes back together
    2007 RCSB|DTR81 built LSx 3xx|PRC|NX|BOGART|MSD|QUICKFUEL 950 E85|4L80|FTI Converters|Smith RaceCraft|Racepak
    midweststreetcars.com
    im headed to oreillys see if they have any good extractors,ive never had to use them before.
    Sep 2006
    THE 405
    Get one of those drivers like I used. You put the bit in it and hit the other end with a hammer and as you hit it, it turns
    ouch i got a headache,just broke the extractor in the stripped bolt
    Oh no...
    Try to lock a vice-grip as tight as possible on the head of the bolt and smack it with a hammer.
    Sep 2006
    THE 405
    It doesn't have a head. They're recessed in the plate. That's I said get one of those drivers...
    Sharpen a small chisel and tap the bolt head on the edge, with a hammer, counter clockwise, of course.
    Maybe you'll get enough bite on the edge to get the bolt loose, that's how we've done it.
    I've loosened many bolts this way.
    good luck,
    allen
