Thread: 4l60e vs. 4l80e
    Nov 2004
    4l60e vs. 4l80e
    What is the rwhp difference between the two?
    *In best Kip voice*
    Like anyone could ever know that...
    H-Town
    Hard to say without side by side dyno runs but there is a difference as I'm sure you know. Comparing my 2500HD dyno numbers to a similarly equipped 1/2 ton or Fbody is rather depressing. Don't have proof but its got to be a good 10-15% in additional driveline loss factoring in the 80e, 14 bolt and transfer case (not sure if your 4x4 or not).
    ________________________
    2006 2500HD, RCLB, 4X4
    6.0, 4L80e, 14 bolt
    Nov 2004
    Lets say that you had a 4x4 1/2 ton truck with a 4l60e trans, then did a 4l80e swap what would be the loss in rwhp. I am sure someone has dynoed there truck with this setup.
    Spring, Texas
    Quote Originally Posted by 2500HD View Post
    Some have claimed as much as 30-40 rwhp but it also can withstand 200-300 hp more than a built 60e.
    Feb 2009
    mississippi
    Quote Originally Posted by ramair2002 View Post
