Results 1 to 10 of 10
Thread: Driveshaft too short after tranny swap...
    Feb 2008
    Ona, W.Va.
    Did a straight up 4l60E for 4L60E transmission swap and ended up with my driveshaft being an inch too short. Does this make any sense?
    What I'm seeing now is what used to be behind the seal (polished, is now new rust) is out beyond the seal by about an inch meaning it isn't engaged on the output shaft as much as it used to be.
    I think this could be a problem, am I wrong?
    Why would 4L60E's be different lengths?
    Eric "The" Pyles
    14.06 @ 96mph / 9.02 @ 79mph
    302 RWHP/298 RWTQ
    mesquite tx
    the new tranny actually "new"?
    ITS MATT SUCKA
    98 rcsb dd
    abosolutely nothin cept flo
    & Nelson Tune
    lookin for project
    bangbangskeetskeet: how big is it v?
    mean05: about 8''
    txarkitekt: I will drink you under the table!
    Feb 2008
    Ona, W.Va.
    Nope, rebuilt
    Eric "The" Pyles
    302 RWHP/298 RWTQ
    Aug 2005
    Apparantly there are different lengths.
    4L60E/4L65E 1996-Later (bellhousing pattern Chevrolet/removable)
    All except Corvette and LS1/LS2
    Overall Length 30 3⁄4”
    Bellhousing Height 18 1⁄4”
    LS1/LS2-style (1998-later)
    Overall Length 31 5/32 inches
    Bellhousing Height 18.25 inches
    Feb 2008
    Ona, W.Va.
    But isn't that the length difference between a non-LS transmission and an LS transmission?
    All except Corvette and LS1/LS2?
    I made sure this was a 4L60E out of an LSx truck. As far as I know, a 4L60E out of an earlier vehicle (non-LSx) will not just bolt in.
    Sorry, I should have mentioned the LS thing earlier.
    Eric "The" Pyles
    302 RWHP/298 RWTQ
    Hope Mills, NC
    are the output shafts the same length?
    2005 GMC RST *sold
    2006 Silverado SS with nawz
    Round Rock, TX
    Check to see if the seals on the tailshaft are the same on both, some have a seal that sits flat with the end of the tailshaft and some have a seal that sticks out about an inch. I may just be a different seal at the end making it look like its shorter...
    Yep...I'm too late....there's a booted seal and a non-booted seal. They need to be used in the proper trans but the yoke and therefore vehicle application should matter. The boot is a about 1" long.
    Bloomingdale Illinois
    Quote Originally Posted by DBRODS View Post
    I'll bet this is the case. Good call. Vince
    Feb 2008
    Ona, W.Va.
    Yep, that was it... comes down to a seal... Thanks for the help guys!
    Eric "The" Pyles
    302 RWHP/298 RWTQ
