Has anyone ever installed a 98-01 stock ls1 cam in a 5.3 - any noticeable difference - .500/.500 lift 116lsa ??????????
I think there is a topic on just that same swap.
If I were you Id upgrade to the LS6 Cam if you wanted to stay that mild. You might be dissappointed with the very low gains with the LS1 Cam. The LS6 is also good if you add Forced induction to your vehicle later on.
I just put that cam in my 01 truck last month. Came out of a 2000 vett. 202/210 .500/.500 116. It made a great improvment and didn't have to change springs. Very good idle, better than stock. Pulls really good after 3k to 6k and will work with a stock setup as well. Got 2 more MPG on a 800 mile trip at Xmas.
I know a couple of guys who have done that swap. They got the cams for almost nothing, so they tried it. When I asked them about it, all I got was a big smile, and an anwer of "worth it."
good to hear...i just put the 01 ls1 cam in my 02 5.3...i will have her running this upcoming week...check this out http://www.ls1truck.com/forums/racer...l-ls1-cam.html
go bigger
05 Silverado RCSB...
LQ9, TVS 1900, 4L80e, & EFI live.
07 Silverado VortecMAX CCSB LTZ Z-71...
Stock... so far
08 Cadillac Escalade 6.2 / 6.0... Wife wagon
I'm in the process of doing this swap but need to verify with you guys -
Engine: 2002 5.3L from Chevy Avalanche, all stock
Camshaft from a 2000 LS1
You guys mentioned that the stock springs can be used. Any difference in the pushrod length or will it be fine?
1993 S10 - 5.3L, LS1 cam/intake, 4L65e
1971 - GM 350 HO/TCI TH350
This is the type of install i did, And what i found out about LS1 cams is that the lift was 496 in & ex. for 98, 99, 2000 and then was changed to 465 in & 477 ex. in 2001...push rods are the same.
2000 sil.ext. 5.3 / Lingenfelter Ls1 cam / LS1 valves / Ported / Milled / 35lb injectors / 80mm tb / E-fans / cold air intake / Pacesetter Cer LT's w/3"ory/ JET-DST / MSD Twister / Corvette Servo / 3.73's / 125 N2O / no cats / Flowmaster exhaust / level rear drop / Rear sway bar / SS wheels / 285/50R20 Goodyears / 05 Tail lites
