Results 1 to 10 of 11
Thread: does a 4l80e take more power to turn than a 60e?
    Twin Falls ID
    i have heard rumors that the 80e takes more power to turn due to its size and parts used (thrust washers instead of bearings) just wondering what other people thought..
    2000 SILVERADO RCSB
    6.0, z06 cam, T76 and a little meth
    built 4l60e by me
    tuned by me
    raced by me!
    WORK HARD PLAY HARDER!!
    Makes physics sense. Not sure if anyone has hard dyno data here. It's not just the washers either. An 80 has more drums and more bands to clamp them. There are less stampings and more castings in an 80.
    Dec 2003
    The gears in a 80e are much are bigger and absorb more power to turn them.
    2000 RCSB forged ls1, 4l80e, t-76
    10.93@124 1.58 60'
    Oct 2008
    Scott, Arkansas
    Quote Originally Posted by quicksilverado View Post
    Not only that but the gearing is kind of MEH compared to the 60 IMO. Now if they made a 5 speed with the 1st gear from the 60 and the other 4 gears from the 80 that would be a monster...
    Quote Originally Posted by chevrolade View Post
    Yup,i Wouldnt Worry About It If U Have A 6.0
    Why? It still eats up a lot of power.. mine is a dog until about 40 mph.
    Quote Originally Posted by ss454327 View Post
    Boy I disagree. A stock 60 has horrible ratios. 1-2 is a killer. An 8- just requires more rear gear because it's close ratio. A 200-4R has the best splits of the 4-speeds but an 80 is a close 2nd IMO.
    Pittsburgh, PA
    look at actual size you can see its larger then the 60. that there should give you an idea
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Wasilla, AK
    It is true.
    Twin Falls ID
    thanks guys for your input.
    brandon
    2000 SILVERADO RCSB
    built 4l60e by me
    tuned by me
    raced by me!
