Results 1 to 8 of 8
Thread: Front leveling kit
    Union, MO
    Front leveling kit
    I am looking to get a front leveling kit for my 2004 Silverado 2WD Ext. Cab. I've noticed there are different sizes and wanted to make sure I got the rite size. I want the front level with the rear. Do I need the 1, 1 1/2, or 2 inch kit? Thanks!
    Mar 2006
    Do you mean rear leveling kit? if so 2inches should get you there.
    Shreveport, LA
    Quote Originally Posted by medic2967 View Post
    Hey tim I think this is going to help you out!!!
    Chevy / GMC Silverado 1500 2wd 2" Front Leveling Kit (Coil Spring Spacers) - 1999-2006
    The back is 2 inches higher than the front, so the two inch in the front should make everything level!!
    2004 gmc sierra No more
    New 2008 Chevy Silverado!!!
    Wasilla, AK
    If you do this, your stock shocks will be overextended, too short. You'll need longer ones. Don't forget to reset the wheel alignment afterwards, it will be way off.
    Mar 2006
    Forget my post, I have just not heard of many people doing this. .
    Kansas
    I did the 2" daystars when I first got my truck and it sat level. Its really not a bad install, I did it in my driveway in 3 hours. take some fender measurements as you may only need the 1 and 1/2" spacers. I can find you part numbers if you need.
    00' RCLB 2wd 5.3 AT: Wheatley Tune, Comp 265H, 706's milled .025, Comp PR's, 918's, Efans, s&b CAI, AEM lt's, magnaflow, ASP UDP, circle d 3200, 4.30's currently down awaiting built lq4
    Union, MO
    Thanks little brother! Those were the ones I was looking at. Not sure if I want to mess with the ball joints and tie rods myselft to get these things on.
    Shreveport, LA
    yeah front suspension is something that you dont need to mess up. Im sure a truck suspension shop would be able to put them on for cheap and fast! (hopefully)
    i think the new shocks would be round 80 bucks for a good pair plus your coil lifters plus your labor.
