Results 1 to 9 of 9
Thread: Question about air conditioning
    Feb 2008
    Georgetown, TX
    Hi, does anyone else who has a 2003 silverado with 5.3l engine have AC trouble?
    During the summer mine will not cool very well, Dealer tells me that a 30 degree temp drop is working fine (on a 90degree day).
    San Marcos Texas
    60 is not cold! It should put out 40-50 anytime.
    Mar 2008
    Does the AC blow warm when the vehicle is stopped or in stop and go traffic, but gets colder when the vehicle is at higher speeds? If so, you're fans may not be operating properly or the condenser has problems. Make sure that your radiator and condenser are clean (i.e. no leaves or dead bugs). Any debris will limit airflow, therefore reducing the cooling capabilities of the radiator and condenser. If the AC blows warm at all speeds, then you may need more refridgerant or there are problems elsewhere in the system.
    Mixing alcohol and Prozac...
    Hutto TX
    Could be wonky temp blend door.
    1991 Silverado ECLB
    LM7-T56
    Feb 2008
    Georgetown, TX
    It does not seem to be cold even at driving speeds. I have checked the front for de-bree and there is none. r6z406 mentioned the temp blend door, I have heard of problems before with that from other people. How do I check it? Also I came across some TSB on another Chevy website that says contaminated refrigerant could be a cause (I'll put it up later when i find it again). Would it better to have it "cleaned" through a recycling machine or evacuate it, replace the orifice tube and then charge it?
    Dec 2005
    Houston,TX
    Make sure your clutch is engaging on the compressor. If it is not then it might be the clutch switch went out which is an easy fix. If that switch went out then it most likely means that your low on refrigerant also.
    s&p headers, custom radiator with e-fans,
    91 sub front end with billet grill and bowtie,
    autometer gauges, red and grey tweed interior, dual 2.5" flowmaster super 40, Dmh cut outs, 5"-7" drop,
    air shocks, 20" Intro twisted vistas, gaylords bed cover
    Mar 2008
    Azle, TX
    Yeah my guess was freon, compressor, condenser, or the pressure switch. Could be something simple or something complicated.
    Take it to a real shop and not the stealership. You really dont need to run it till its fixed cause you could cause damage to other parts mainly the compressor, which Im sure you know is usually the most expensive to replace.
    2005 Crew Cab 1500HD aka "Big Beast"
    6.0L Cam'd & turbo'd **SOLD**
    '03 Cummins straight piped and a programmer
    "I bought a Cummins and it came with a free Dodge!"
    Mar 2008
    Azle, TX
    LS182 your truck is sick!!
    I love the 78-87 body styles when done right. Good looking truck!
    Sorry to thread highjack....it just needed to be said lol!
    Dec 2005
    Houston,TX
    Quote Originally Posted by hebdog View Post
    Thanks 4 the compliments!
