Just wanted to let the Austin area guys know that my cousin and I are doing gear and posi swaps at my house in cedar park for $150. You buy all the parts and we install. Install time is an estimated four hours max. Richmond gears are really good but can be a bit noisy some times, Motive gears are also good and a bit quieter. As for posi thats ur choice please make sure you buy all the needed bearing and seals to do the swap also will need 3 quarts of gear lube, posi lube is needed if you are using regular gear lube. I suggest Royal Purple of Lucas gear oil.... Since the Royal Purple and Lucas are synthetic they do not need the posi lube or friction modifier....... Just send me a PM......
