Well last night I was messing around with my step dad in his 2003 quad cab Hemi. He thinks it's the greatest thing alive, well my 4.8 ext cab showed him. He pulled me about a car length on take off then we cruised by him in second and left him in third. After we raced and played around I had to turn around in road and noticed my power steering wasn't working. We stopped on the side of the road to check it out. The pump is full with fluid and the belt and pulley are working fine. I got under the truck to check out the rack and pinion, and it appears to be ok. I got back in the truck and started it up then slowly opened the pump cap to check if I could see any movement of the fluid in the case. It doesn't seem to be moving, swirling, nor is the level changing. There are no leaks or anything. I drove it home and the rack and pinion seems to be working fine it does not jamb or stick at all in it's movement it just doesn't have power assist. I am pretty sure the pump has just gone out, but wanted to check with you guys to see what you all thought. Any help or thoughts would be great.
2002 Silverado 2500HD LB7 CCSB LT
EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's
2004 Tahoe LT
2006 Silverado Z71 LS
1971 Chevy C10
