Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: Turbos and Braking
  1. #11
    I don't have hydroboost and I dont have any problems.
    99RCSB Sway bars bear brakes Mcgaughys lowering kit. Trick turbo, comp cam, patriot dual gold springs. Huge Oil cooler. 02 PCM, new FLT 4l85 PI converter. Handles like a vette but is faster. Yea its AWD. I still tow a trailer. TBSS for the Mrs. Yes I am likely to misspell a word or too and am not likely to be grammatically correct. No I don't care. 208º/214º .554"/.559" with a 114º lobe center .I need a better cam.
  2. #12
    Palestine, TX
    why not use a Line Lock system? lock the front brakes when your boosting at the line and then push the button! oh and apply the gas pedal floorward
    02' Silverado RCSB, CAI, LTs+ORY, 65E Servos, 1.75:1 SS-LW shaft rockers, Custom E-fans, Black Headlights and Bumper Lights
    Up Next: 2/4 drop, 18'' titan 5spokes, forged 370ci, Beefed up 60E with HD2kit
  3. #13
    This thread is about his power brake booster not working when he wants to slow down because of boost. Buddy must be new.
    '06 Silverado
    "CASH"
    It does the ton.
    It is heavy and long, delivery might be killer.
  4. #14
    Dec 2008
    florida
    i run 10lbs of boost and dont have any problems, once you let off the gas it goes to vacuum and your brakes work fine, the booster has a check valve built in so it wont be damaged. it wont hold power very well trying to launch with an automatic, it was ok but i could only hold about 1700rpms at the line, i just swapped in a manual trans so i never really did anything about it as it doesn't matter now.
    95 Chevy k1500
    4 bolt main 355, forged lightweight pistons, dart iron heads, lunati cam, whipple supercharger@ 8psi, methanol injection, built 4l60e, to much to list completely.
  5. #15
    Saint Marys, GA
    Quote Originally Posted by casey23 View Post
    No LOAD = NO boost....
    +1 My truck brake stalls fine off the line
    Current Mods: 6.0/4L80e with Trick Performance Front Mount
    Audio: Pioneer avic-d3, Memphis Belle, Two 12" Rockford Fosgate P3 shallow mounts, Memphis MS-Qs, and custom vinyl enclousure.
  6. #16
    Feb 2008
    Silver Spring, MD
    Quote Originally Posted by sleeper1500 View Post
    So HA
    Ha indeed!
  7. #17
    Austin, TX
    You buy my hydrobooster parts I hve for sale in the for sale section!!!!!!
    http://www.ls1truck.com/forums/sale-...onversion.html
    5.3, E-fans, LPP longtubes w/offroad Y, Dual Magnaflow, K&N Cold Air, 160 thermo, Voodoo 212/218 .531/.531 113 cam, Nelson Tune, 4:11, Built 4L65E, 3000 Circle-D converter
