ya, it is quite a bit difference, gonna need a 3.5" vband for the exhaust and 3" vband for the cold side.
i'll look into it and get something going for you.
Hi dudes,
I just recived my stuff from Nelson Performance (Turbo, Camaro SS 2010 Tuned, etc) and got some problems Installing my New Turbo.
Only thing that bolts on is the T4 flange, other than that I´m clueless for now.
I wanna be the Biggest Front mount Turbo instaled around here...humm, forget it, I´m the only one !!!
Any way, can you help me with the flanges and stuff, and also what Heat Jacket will fit this sucker? (t4 or T6)
Thanks in advance for all the Help. Some pics.
EcoPerformance
Performance Programming and Installation
Nelson Performance
'94 Chevy Truck, ls swap w/ twins
Turbocharged Dragalanche
what size turbo is that?
346/front mount
Allen,
Cool, also just order the 2step and just waiting for the trans and the 4 link to arrive, so is gonna be a busy month.
The turbo is a.... well kind of a T88...I think !
EcoPerformance
i heard they were coming out with a 88mm, but didnt think it was out.
346/front mount
looks like they got it done!!!!
'08 trailblazer...stock
'07 gmc cc z71 stock
Nelson performance SD tuned '04 excab, 6.0,Nelson performance front mount turbo with mpt-76 turbo, gt2-3 cam, 4l80e tranny , circle D stage 3 1-a converter , 05 efans and radiator , 160 t stat , general uhp's on black esky widened 17's , addco front and rear sway bars , 14" big brake kit and some other goodys...550/550 power
from what ive heard they are available as a custom order. but i heard that awhile back
346/front mount
No, it's not a MP T88... Looks like a MP45. Has a 76.5mm compressor with a .60 a/r and a 77.5mm turbine wheel with a 1.22 a/r. Mp rates this turbo at 7-900 fwhp. they have been making these for quite a while. Its the same compressor wheel they based there T76's off of.
01 ECSB 1/2 ton 4x4 Forged 5.7 LS1 GMC
12.21 @ 110.5 at 4800' elv. (6800 DA)
KB Racing S480 Turbocharged!
my question is WHY?... i understand bigger/better...... but i didnt see you ever post enough boost logs and info to think about a turbo upgrade... and that 76mm Turbonetics isnt a chump turbo....
02 Chevy apart ...
