VIDEOS PHOTO HOSTING FORUM RULES | BECOME A SITE SUPPORTER
LS1Truck.com
Go Back   LS1Truck.com > Technical Discussion-GM Trucks > Power Adders
Power Adders N20, Turbo/Supercharging
This forum is for all makes and models.
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 11-13-2009, 09:23 PM
greasemykey greasemykey is offline
Junior Member
turbo 5.3L or 402
i want an honest opinion. should i build a 402 and drop it into my 2wd silverado or should i turbo the 5.3L i have now? i have a few bolt ons and a tune but i want power. i changed the rear to a detroit tru trac with 4.10 yukon gears. just asking an opinion and seeing which way to dump 4500 bucks.
  #2 (permalink)
Old 11-13-2009, 09:48 PM
keniff keniff is offline
Paid Off
front mount turbo imo bc you can always upgrade motors later vs spending 5k on a motor then another 5k on a turbo..id rather the front mount turbo now then build a motor later
__________________
  #3 (permalink)
Old 11-13-2009, 09:50 PM
Quik's Avatar
Quik Quik is offline
Your God
depends on what youre plans for setup is.
__________________
People in general dispise others who are better at what they do than they are, in fact they can create whole cults to mock you due to their lack of intelligence and character.... we all handle this differently.
  #4 (permalink)
Old 11-13-2009, 09:57 PM
STUNNA's Avatar
STUNNA STUNNA is offline
CHEVY
motor swap
__________________
  #5 (permalink)
Old 11-13-2009, 10:06 PM
SNEEKY SNEEKY is offline
sprayin the whole 1320
motor swap. when you get tired or need more power from the 402 then put some spray on it. Thing will be fast with the right suspension setup
__________________
2005 GMC RST
  #6 (permalink)
Old 11-13-2009, 10:48 PM
randomhero's Avatar
randomhero randomhero is offline
Senior Member
For me personally I'd stick with the 5.3. With a 402 your gas mileage will go to crap, and I see so many people part their trucks out after doing a large displacement motor swap.
  #7 (permalink)
Old 11-14-2009, 08:20 AM
Junior Member
Quote:
gas mileage isnt an issue. i would drop an 8.1L in if there wasnt so much extra crap i would have to swap. i have a motorcycle and a new excalade i can drive instead of this thing if gas prices go up again.
who else besides sts makes a turbo kit. i found one other but they dont have the carb oe numbers. so every time i have to smog the truck i would have to take it off.
  #8 (permalink)
Old 11-14-2009, 10:34 AM
smoothdime smoothdime is offline
Senior Member
motor swap. that way if you decide spray or boost later the engine can handle it safely.
__________________
(SOLD)2000 ECSB HARLEY DAVIDSON EDITION. 2''/4" DROP, 20" BUDNIKS, COWL HOOD, MOLDED ROLLPAN, CLEARS, DROP IN K&N, MIT, TAYLOR WIRES, LOUDMASTER EXHAUST
1991 RCSB S10 355 SBC, 700R4, 8.5" 10-BOLT, 18"/19" Z06 WHEELS, 4"/5" DROP, MAGNAFLOW DUALS W/X-PIPE, FULLY SHAVED W/ CADDY LIGHTS
  #9 (permalink)
Old 11-14-2009, 12:34 PM
kbracing96 kbracing96 is offline
Senior Member
I do, Nelson does, and Trick, but none of them have CARB approval. Only one is STS and its only on 01-05 I believe. AS far as what's better, depends on what you want to do with the truck. A 5.3 with about 7 psi of boost will make about the same power as a 408, but then you can turbo up the boost and make more power then a NA 408 if you want!
__________________
01 ECSB 1/2 ton 4x4 Forged 5.7 LS1 GMC
12.21 @ 110.5 at 4800' elv. (6800 DA)
KB Racing S480 Turbocharged!
http://i3.photobucket.com/albums/y57/Kbracing96/kbracing96copy-1.jpg
  #10 (permalink)
Old 11-14-2009, 04:32 PM
4.8t 4.8t is offline
Member
i like my turbo 5.3l it makes my pig move pretty good. then again i do care somewhat what my mileage is. but down time on the install was way less than a motor build also.
__________________
'04 Tahoe AWD,5.3L trickperformance turbo kit, magnaflow muffler and SC3200. 12.89
http://videos.streetfire.net/video/t...289_708232.htm
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright 2002-2007 LS1Truck.com
Search Engine Friendly URLs by vBSEO 3.0.0
