07-03-2009, 03:41 PM
Senior Member
One of the mags I get did a good comparison on two NA engines, 300hp vs 500hp.
Add 14psi to them.
What I'm getting at is, build a strong NA engine and boost it, you'll have more power in the end.
300hp + 80% = 540hp vs 300hp
500hp + 80% = 900hp vs 500hp
Now it's no longer a 200hp difference like it originally was.
Now it's 360hp difference.
See how it works? Same pressure, however, but different engines.
Pretty big jump when you look at it that way.
Mic's truck is probably making some good power anyway NA, add boost, it's gonna make some good power in the end.
I didn't want to post the details about the 408 I built for a customer and hear all the nay sayers slam it.
But just a quick summary, 821hp from 13psi. Why? The 408 had 10.6 compression. I didn't need to build it with 8.5cr and throw 20psi to it, customer wanted 700hp to the wheels, he got more though.
So, set your goal and build the engine strong, then boost it.
That engine was about 940hp at the crank with stock heads, intake and throttle body.
07-03-2009, 05:58 PM
Turbo Moderator
So track tonight?
__________________
2002 GMC Sportside Denali front end with a 2002 LS1, FLT level 5, Yank 2600, Trick Turbo, T76, Nelson intercooler, 60LB injectors, Warbro fuel pump, Eaton locker, Magnaflow, 3.42, Nelson Performance Tuning (speed density).
1981 GMC LB RC 1500 2002 4.8L 4L60E 12 bolt 3.73 Richmond Lock Right AC PS Nelson Performance tuning
07-03-2009, 06:47 PM
Site Supporter
Make sure its all right before going, or it just wastes time, money and sometimes an engine.
__________________
Custom fabrication to fit your needs.
07-03-2009, 07:35 PM
LS1Truck Moderator
Yeah I knew that...was just thinking he had a 6.0l similar to mine - forgot about all his extras.
Quote:
Add 14psi to them.
I forget Mic has the stage 2 heads, Vic Jr., and 90mm tb, and bigger cam. Makes sense now.
07-05-2009, 10:19 AM
Senior Member
i cant wait to see some track times.
__________________
01CamaroZ28
10.751 @ 124.26 mph with a 1.446 60ft
ALL THRILLS NO FRILLS!!!!
B&L Racing stg 1 heads 224/581 cam.
06 silverado 6.0L VMAX stock for now.
07-08-2009, 08:49 PM
10 sec club!!!
hmmm...high compression and low boost...imgaine that...LOL
__________________
1995 ECSB, LS2, Wiley 80E, 3400 VIG, 4.10 Motive Gears, Detroit locker, Magnaflow stainless exhaust, 4link
