Page 13 of 14 FirstFirst ... 3 11 12 13 14 LastLast
Results 121 to 130 of 140
Thread: Need more MPG from my 2006 Z-71
  1. #121
    Lafayette, La.
    It looks like this thread is almost dead but I have another update. The cooler air is doing wonders for my engine. I tried a 78mm throttle body but my truck slowed down in 60 ft, et and mph. I ran best with my stock body that I ported. My et improved .3 and my mph but almost 2 with better tuning and a port job on my factory TB. My 60 ft still is pretty bad but everything else is looking up. I just got in some 1.8 rockers that I will add before I run again. Also waiting on some more cool air. I can tell a noticeable difference when the temp gets in the 50's.
    2006 Chevy Silverado Crew Cab Z-71 5.3L, Custom Tune, Volant CAI, 4.10 gears, pacesetter LT's, Y-pipe, high flow cats, comp cam 202/212 500/507 cam, magnaflow muffler, msd coil packs, 1.8 rockers, 31lb injectors
  2. #122
    Lafayette, La.
    I was hesitant to install the 1.8 rockers even after I bought them for fear that my mpg would drop. After they were installed, I was suprised to find that it did not drop and may have actually increased with the new rockers. My 60 still is horrible and I could gain a lot by changing to a higher stall convertor. Gonna debate that idea some more as I drive 50 miles a day back and forth to work. Anyone still out there?
  3. #123
    Augusta, Ks
    What are your updated times?
    2000 Silverado ECSB- 5.3 CAI, Pacesetter LTs, ORY- Pipe, Magnaflow XL, E-fan, Ported T/B , Nelson Tuned, Built 4l60e, Circle D Stall, 3.42s G80, 2-4 Drop, Hertz Highs, Rockford 501s *Waiting to be Installed* 220/222 .581/.581 114lsa
    2007 Hyosung GV650 The Little 650 Cruiser that could. 12.7 at 104 Mph
    2004 Buell XB12s
  4. #124
    Mar 2007
    Newark, Delaware
    I'm assuming your 50 mile commute is mostly highway, correct? Once you're in overdrive and the converter locks, it's the same as a stock stall locked converter. That's why highway mileage is affected very little by high stall converter swaps.
    99 Silverado ECSB 4X4, LQ4, Patriot Stage 2 243's w/ 59cc chambers, TR224-112, Pacesetter LT's, Nelson tune, FLT Lvl 5, Yank 3k stall, UD pulley, CAI, Ported Throttle body, 160* t-stat, E-fans, 6'' Fabtech lift, 3'' Summit body lift, 37'' ProComp XTerrains, 4.56's, 4'' shackle flip 13.78 @ 98mph on 37's FTW! Coming soon:
  5. #125
    Sep 2004
    Breaux Bridge, LA
    Quote Originally Posted by Beatdown Z View Post
    that's what i been telling him.
    03 Silverado RCSB
    12.41@ 104 n/a
    11.74@ 112 75 shot
    04 Silverado CCSB Z71
    15.67@ 90 n/a
  6. #126
    Lafayette, La.
    Commute is about 50/50 city/highway. My 60 ft is still in the low 2.4's which is my main et downfall. My 4l60e is still stock which will have to be beefed-up if I continue to make more power. Does anyone know anything about the 6 speed trannies used in the newer trucks? Is the OD gear the same or would there be any benefits to going to it?
  7. #127
    the boro, tn
    now i ain't an auto guy, but don't the new 6Lxx transmissions have a separate transmission computer or something like that?
  8. #128
    All the new GMT900 series trucks have a seperate tranmission computer.
  9. #129
    Lafayette, La.
    6L60e trans
    Can anyone give me the gear ratio differences between the 6l60e and 4l60e transmissions? I know it has it's own controller but how much would it drop my rpms at 70mph? Right now with the stock 4l60e, I am at 2250 with 4.10 gears which is hurting my mpg. If the 6l60e has lower first and second gears, that would help my low end problem. Anyone do this swap or know where to find info on it?
  10. #130
    never heard of or seen an RPO code for a 6L60e transmission. Are you talking about the 6L80e?
