One of my newest builds on a 2004 GMC Seirra. Customer trashed stock 10 bolt twisted one axle spline and broke the other
at the center! The 9" was re tubed with .375 tubing vs. the stock .188 wall. That was to help aid
in the twisting, along with the custom truss that was fabed from 1/4 plate from spring perch to
spring perch. Loaded with 35 spline axles, detroit locker, good gear set, and a Pro Series 3rd member also
used a daytona pinion support. Also added Willwood disc brakes.
Looks good!
99 GMC - RCSB 408 w/98mm whistle...WSLS Racing...
Looks good! How much for a setup like that?
Nice! What ratio are you running in it?
Customer requested a 3.50 gear set.
cant use factory discs?
We are literally on the topic of trying to
Make that happen. That's the one thing im
Striving for right now, because that
Would give y'all the ability to use all your
Factory equipment.
