Page 6 of 7 FirstFirst ... 4 5 6 7 LastLast
Results 51 to 60 of 71
Thread: Trailblazer Ss Intake Swap With 02 Rado
    Feb 2010
    i was going to use the stock 02 rails but i think im going to try to find a set of tbss ones now, is that all you have to do to make it work is buy a vette fuel filter and they all just snap to geather
    wichita falls, tx
    Quote Originally Posted by 02chevyls1 View Post
    if you choose to mount it on the fuel rail, then yes, it all snaps together
    4.3 swapped to 408,
    Mods:TSP MS3 cam, WCCH L92s, Wiseco 4.030 -3cc pistons, magnaflow, nelson tune, longtubes, ls1 efans, 3.90 and TruTrac.
    4/6 drop, HD front end
    Feb 2010
    i found a set of 06 lq9 injector rails with injectors, off of a 06 cadillac ext with a 6.0 h.o motor the lq9 has a inlet and return fuel line does any one know if that will work in the 06 tbss intake and will the inlet and return lines fit in the stock 02 fuel lines
    Broken Bow, OK
    Well after looking at some more intakes, the MAP sensor is different on some. I guess it depends on what year you get the intake from. Mine was from a 2008 and it still has the old style MAP. Looks like 09-10s have the newer style.
    if putting a 06 tbss intake on a 05 6.0 crew cab truck, would the factory 06tbss fuel rails work without modification? it seems like the biggest mod is making it work with a return style fuel system, but my 05 is returnless correct?
    2005 crew cab, new crate lq9 with comp 212/218, 558/563 on 115 cam, 80mm t.b. coated long tubes, off road y, flowmaster cat back, dynomax bullet, ngk plugs, msd wires, k&n cold air kit, 4.10 gears, auburn pro lsd, transgo shift kit, nelson drive tune, trailblazer i-6 torque convertor, anzo lamps, ss front bumper, z71 tahoe rear bumper, debadged, kenwood touchscreen with headrest monitors, JL components, coaxials, sub, 5ch amp. bell tech 2/4 drop. 22x10 ss wheels with 285/35/22 bfgs.
    Broken Bow, OK
    Quote Originally Posted by MEANGENE75 View Post
    Yeah, won't be a big deal for you. The fuel line will plug right in.
    good to know. what injectors would that setup use? is there an injector that physically fits the 06 tbss intake and rails, but has the electrical connector that plugs in my 05 truck harness?
    Feb 2010
    what size injectors would the h.o lq9 have
    and does any one know where i can get 06 tbss rails and injectors, there discontinued by gm
    Feb 2010
    will my 02 wires plug into the 06 tbss injectors
    Broken Bow, OK
    No, unless your 02 happens to be a flex fuel truck. Which I doubt unless it is a Tahoe or Burb.
