OK I have a couple of radix questions for yu guys. My buddy is running a radix with 8 to 1 forged pistons lunati rods, 6.0 block and patriot stage 2 heads. Here are my questions.
1. What is the most boost any of you guys have ran on a radix?
2. He wants to crank the boost to atleast 16lbs. I know at 13lbs the belts on whipples slip and you have to go with a cog set up.
3. Does radix make a cog set up and whats the highest rpm you can spin a radix at magnacharger says 16k???
old set up: 2002 chevy 5.3, procharger 12lbs boost, asm headers, ls1 edit, flames, 20inch budniks
New Set up: 2004 chevy 5.3 ext cab, 12 inch twisted suspension lift, 36's, exhaust.
future mods: 150-200 shot, ls1 edit, air intake, stall, 5.13 gears, 12s or bust
