VIDEOS PHOTO HOSTING FORUM RULES | 2009 LS1Truck Raceday at SAR
LS1Truck.com
Go Back   LS1Truck.com > Technical Discussion-GM Trucks > PCM Tuning and Diagnostics
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 11-20-2003, 10:09 AM
SixliterHD SixliterHD is offline
Senior Member
Send a message via AIM to SixliterHD Send a message via Yahoo to SixliterHD
Well 1st of all its nice to be back to where I can get some internet service. I have been on a rig with no phones or network. Ohhhh Boy
Now about LS1 edit
Have you used it? If so how hard is it to use? Does it have a setting that will take you back to totally stock if you totally screw it up? Do they have a chart that shows what settings are good for certian setups?
I am considering buying it to tinker with my computer and see what I can do with only computer work.
Thanks in advance,
Brad
__________________
http://www.danasoft.com/sig/bsnuggs.jpg
2001 GMC 1500HD SLT 4X4 CCSB 6.0L
Mac Performance Intake, 05 E-Fans, Magnaflow Catback, Pacesetter LTs w/ Custom "ORY", Comp Cams 210/210 555/555 112 lsa, Comp Cams 918's, Hardened Pushrods, HP Tuners, BB Thermostat mod, TBBP, EGR Delete.
Not EVERYONE can be a Louisianaian, it's an art form and a gift from God!!
Treat every situation like a dog; If you cant eat it or screw it-- Piss on it and walk away
  #2 (permalink)
Old 11-20-2003, 10:15 AM
Senior Member
OK I must be smoking crack. Allen can you move this over to the proper section. I dont know what I was thinkin.
__________________
  #3 (permalink)
Old 11-20-2003, 04:53 PM
farmtruc's Avatar
farmtruc farmtruc is online now
Senior Member
Send a message via AIM to farmtruc
Edit definitely takes some patience and there's really no manual for it, it does come with some instructions on how to get started and covers some of the very basic things.
You can save your stock file incase you want to go back,
however it's not fool proof, you can destroy your pcm if you have connection problems.
allen
__________________
Performance Programming and Installation
Nelson Performance
  #4 (permalink)
Old 11-20-2003, 06:31 PM
Senior Member
and how many have you smoked?
lol
so what do ya mean connection problems --like a dirty terminal or like the data comming from the laptop back to the pcm
What does a new pcm run about
if i buy it and decide later that i would like to go to the unlimited license can i just up grade or do i have to buy it all over again
thanks for the help allen
__________________
  #5 (permalink)
Old 11-20-2003, 08:40 PM
farmtruc's Avatar
Senior Member
i haven't smoked any, due to my fault, hahahah
a new pcm is about 120 bucks, then about 70 bucks to get it flashed with a stock file. then you can edit it.
if you buy the single version, and then buy the unlimited, you'll have to start over.
__________________
Nelson Performance
  #6 (permalink)
Old 11-20-2003, 09:51 PM
Senior Member
so i have to have them flash it even if i have the stock prog from the one that smoked?
__________________
  #7 (permalink)
Old 11-20-2003, 09:56 PM
farmtruc's Avatar
Senior Member
ya, if you mess a pcm up, sometimes they are repairable, sometimes you have to buy a new blank one, either way you have to have it flashed.
allen
__________________
Nelson Performance
  #8 (permalink)
Old 11-21-2003, 05:04 AM
SSilverado60 SSilverado60 is offline
Member
Send a message via AIM to SSilverado60
Yeah screwing up a PCM because your laptop messes up can really ruin your day.
Dont be afraid of frying PCMs or anything like that. Just make sure your laptop or whatever pc youre using to program with wont screw up on you or your gonna be paying $70 at the dealer to reflash it with the Tech II the next day
  #9 (permalink)
Old 12-29-2003, 07:15 PM
blown02 blown02 is offline
Senior Member
There is a company out of fresno ca, that tuned my truck with edit and i was real happy with it. www.speed-eng.com
__________________
old set up: 2002 chevy 5.3, procharger 12lbs boost, asm headers, ls1 edit, flames, 20inch budniks
New Set up: 2004 chevy 5.3 ext cab, 12 inch twisted suspension lift, 36's, exhaust.
future mods: 150-200 shot, ls1 edit, air intake, stall, 5.13 gears, 12s or bust
  #10 (permalink)
Old 12-30-2003, 07:19 AM
Chingon Chingon is offline
Senior Member
So then if you have LS1Edit for one PCM and you fry that PCM and get a new one, you're screwed right? Or can you tell carputing.com what happened, send your LS1Edit cable back and have a fresh one given to you? Or will you have to buy a whole new $550 Edit license?
__________________
'01 Sierra 4.8 SCSB
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright 2002-2007 LS1Truck.com
Search Engine Friendly URLs by vBSEO 3.0.0
