VIDEOS PHOTO HOSTING FORUM RULES | 2009 LS1Truck Raceday at SAR
LS1Truck.com
Go Back   LS1Truck.com > Technical Discussion-GM Trucks > PCM Tuning and Diagnostics
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 11-03-2003, 11:44 AM
Trucked-up Trucked-up is offline
Junior Member
Dynoed my truck this weekend while hooked up to EFI Live.
I have a 99 GMC with a 99 LS1 from a TA. Truck intake and truck computer. Stock internals.
Starting at approximately 70% throttle I am getting knock retard. It ends up pulling about 5 to 7 degrees of timing. Timing advance is only about 14 to 16 degrees.
We changed the timing advance using EFI Live and did another run. Same thing.
I have deleted torque management.
Question, do I use the knock sensor from the LS1 or the knock sensor from the truck. Does it really matter?
Any other suggestions?
Truck runs fine otherwise.
Thanks
__________________
99 GMC, ECSB w/ LS1 from 99 TA
E-fans, 3:73, Eaton posi
  #2 (permalink)
Old 11-03-2003, 12:20 PM
farmtruc's Avatar
farmtruc farmtruc is offline
Senior Member
Send a message via AIM to farmtruc
Did you get to look at your ltrims and a/f ratio, usually kr is due to running lean?
The ones that i've done, i've used the truck and ls1 knock sensors, i'm not too sure if it makes a difference.
You didn't post your HP/TQ times, how did the dyno turn out?
allen
__________________
Performance Programming and Installation
Nelson Performance
  #3 (permalink)
Old 11-03-2003, 11:18 PM
gr8twhite gr8twhite is offline
Member
Send a message via Yahoo to gr8twhite
What is knock retard? I've got a 3.0 pulley to replace the 3.40 thats on now.He said it will be ok because i run 93 octane, but I need to watch out for it.
__________________
2000 SWBRC 5.3,radix,e-fans,no cats,true duels
2 21/2in delta force race muffs,4.10 with eaton
e-locker.Descreened MAF & throttlebody bypass.
FLP level 5 4L65E,PI 3000 stall,Dynatech headers
Nelson tune
2005 GMC 2500HD 4door 4x4
1989 Chevy Suburban 4x4 ( Sir Leaks-a-Lot )
  #4 (permalink)
Old 11-04-2003, 07:17 AM
Junior Member
My LTFT were in the +6 range for both sensors.
The engine is rated at 305 hp at the fly wheel, I got 250 hp and 296 lb/ft of torque at the rear wheels.
Do you think I need to make sure that I deleted torque management correctly?
Thanks
__________________
  #5 (permalink)
Old 11-06-2003, 10:32 PM
farmtruc's Avatar
Senior Member
Quote:
Knock retard is that pinging noise you here when a car has cheap gas, bad timing or something like that, to make it simple, lol, the technical definition is this:
Detonation (also called "spark knock") is an erratic form of combustion that can cause head gasket failure as well as other engine damage. Detonation occurs when excessive heat and pressure in the combustion chamber cause the air/fuel mixture to autoignite. This produces multiple flame fronts within the combustion chamber instead of a single flame kernel. When these multiple flames collide, they do so with explosive force that produces a sudden rise in cylinder pressure accompanied by a sharp metallic pinging or knocking noise. The hammer-like shock waves created by detonation subject the head gasket, piston, rings, spark plug and rod bearings to severe overloading.
it's bad!!
ya, if you can't hear the pingin, you're ok for a while, but you should get it checked out, oh wait, you're coming down for tuning so we'll get it straightened out, hhehehe,
see ya soon,
allen
__________________
Nelson Performance
  #6 (permalink)
Old 11-06-2003, 10:34 PM
farmtruc's Avatar
Senior Member
Thanks
Ya, your ltrims are positive, so that could cause detonation, i richen up the injectors when i see that, it usually cures the pinging.
do you have edit, how did you delete TM?
allen
__________________
Nelson Performance
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright 2002-2007 LS1Truck.com
Search Engine Friendly URLs by vBSEO 3.0.0
