08-26-2003, 11:13 AM
Senior Member
that's a tuff one, i guess the only ppl that would know is hypertech. I know on the ls1edit side, you have to be careful as to which file you flash pcms with, just becuase they're the same year, it may have a different version, which will destroy the pcm is flashed with the wrong version.
just curious, why are you buying the hpp3?
for power or to recalibrate the gears/tires.
later,
allen
08-27-2003, 08:46 AM
Turbo Moderator
I think that 2000 and 2001 have different wireing harnesses but I might be wrong. Check the pinouts!!
__________________
2002 GMC Sportside Denali front end with a 2002 LS1, FLT level 5, Yank 2600, Trick Turbo, T76, Nelson intercooler, 60LB injectors, Warbro fuel pump, Eaton locker, Magnaflow, 3.42, Nelson Performance Tuning (speed density).
1981 GMC LB RC 1500 2002 4.8L 4L60E 12 bolt 3.73 Richmond Lock Right AC PS Nelson Performance tuning
